Hi all, I need some help the other month I upgraded from a intel i7 4790k to a ryzen 9 5900x got all the parts working and boots works fine but after awhile it just goes black both screens off keyboard and mouse lights turn off no input from keybaord or mouse pc is still on lights but wont react to power button trying to turn it off so the only way to turn it off is at the power supply switch then works again, from what I have tried different thermal paste plus aio from point 1. Ive kept my eye on temp before changing the thermal paste it was hitting 90c so after the thermal paste haven't had a problem but just like 2 weeks later done it again any ideas from any of you specs below. If any of you have any ideas im just looking for a answer because dont want to go out buy more stuff if it not thats the problem.
Case : Nzxt H510 - I know I should've got the H510i because of the front mesh if it really is just that, I am awear that it really could just be because of the heat but I thought about asking first just incase it doesnt fix it.
CPU : Amd ryzen 9 5900x
AIO : MSI Mag 240R
Motherboard : Gigabyte Aorus a520 Elite - In bios was looking for the PBO settings because of the under volt thing it does on the 5900x and brought the temp down but still happens, keep not that PBO 2 isnt on my version of the bios even with the new bios update so I don't think this motherboard supports PBO2
GPU : Asus 2060 Strix
Power supply : Corsair rm750 - Also got a older 850 but on my old build after like 7 years of use didn't turn on the first time had to reset the button and on the 2nd time booted fine so I assum the PSU  was going.
https://linustechtips.com/topic/1417210-my-computer-issues-help-needed/
AIO : MSI Mag 240R
Also forgot to mention ryzen master is also saying I cant overclock because the cpu isnt supported any advice ?
AIO : MSI Mag 240R
dont get a 5900x as its overpriced and overkill for your gpu look at a 12700k if you want powerful and to have upgrade options. Also if you dont a 12600k is also good if you have time maybe wait for 13th gen. with the extra £100 you saved get a b660 board
Already have all the parts now just looking for a solution now
The reason I went for the 5900x is because im playing on upgrading gpu in the near future plus I do editing or film stuff so need the power future proofed myself
try booting off of a different drive with a fresh install
AIO : MSI Mag 240R
Have you cleared the CMOS?
Do you have the newest stable BIOS?
Would i still have to clear the cmos after buying new ?, but up to date on the lastest on gigabyte f14 so tbh I think im just gonna have to buy a new Motherboard because even in ryzen master app cant do anything other than view stuff
