6 minutes ago, Shimejii said:
do you have always onscreen display? thats a drainer, or GPS location
Nope, only thing I got turned on is wifi. I think I might have even closed everything before going to sleep. Plus only a few percents of usage are registered in the log, as the pic shows.
https://linustechtips.com/topic/1416913-s22-battery-issues/#findComment-15295971
Geo location doesnt always show up in battery as well as on screen stuff. Usually its something pinging, such as your Cell provider
https://linustechtips.com/topic/1416913-s22-battery-issues/#findComment-15295980
The 5 mins of screen on was after I woke up, it was sitting on my nightstand while I was sleeping. 😕 I don't know what could it be, but if it keeps happening I'll have to get it serviced or returned, because this battery performance is worse than my 3.5 yrs old S8's.
https://linustechtips.com/topic/1416913-s22-battery-issues/#findComment-15295998
