So a few of the things that i would like to add to my system is a custom loop and SSD's. Both of these will eventually be added.
So a full custom loop with a 360 and 240 mm radiator or two 250GB SSDs and a 2TB HDD
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/141683-custom-loop-or-ssds-and-hdds/
would you even use the storage?
Yes, once i had it i would start to build up media, which i could just get a dedicated NAS
| F@H STATS |
Why would you watercool a 660ti?
I couldn't, its a non-reference design. Also it would be just a CPU loop for a while until i can get another $500 to get what ever is equivalent to a 780 at that time.
Also that little 660Ti is bad a**, lol, can u curse on these forums
| F@H STATS |
A new graphics card. This will provide more of a tangible benefit than the other upgrades, and will allow you to buy a waterblock in a few months or whatever when you put it all under water.
However, if you live by the little quote near your picture, you've given yourself the answer. ;)
Though I will say I think CPU-only custom loops look kind of silly, but that's subjective.
If you have your heart set on storage or a loop, I'd say go for the loop sans one radiator and get an SSD and/or a HDD (two large radiators is overkill for just a CPU, anyway). If all you've got is that 500GB in your sig, you need a storage upgrade. :P
CPU-AMD FX 8350 @ 4.9Ghz | GPU-Sapphire 7970 OC | Motherboard-AsRock Extreme9 990fx | RAM-8GB Mushkin Blackline Ridgeback
Case-NZXT Switch 810 | Heatsink-NZXT HAVIK | SSD-Samsung 840 250GB | HDD-Seagate Barricuda 1TB; WD Green 2TB
PSU-Seasonic X-Series 850 Watt | Mouse-Razer Naga | Keyboard-Razer Blackwidow | Speakers-Logitech z623
I changed it just as you replied. I will choose colours over performance. Im getting thin power coated white rads instead of thick black ones when i do get the loop and honestly that little 660Ti plays all my games for now. I might end up getting EVGA's 6GB 780 so i can use it for a while (I will only get it if its reference) and honestly im just now getting to the point where i have less that 100GB empty on my HDD and i don't really plan to fill it up to much more unless i had the extra space.
| F@H STATS |
