Need help 9900ks temp spikes
Solved by Skiiwee29,
if one core is overheating and the rest are good, then its definitely a problem with the paste under the IHS from the delid. You will need to delid it again and redo the paste.
Featured Topics
Hey_AND1 ·
Posted in Peripherals0 -
INotPablo ·
Posted in New Builds and Planning1 -
1
EdoTensei ·
Posted in Graphics Cards2 -
Idkwhattodowithmylife ·
2
1
