Hi everyone,
I just recently built my PC a month ago and I started noticing some screen freezing issues three weeks ago. I get two different types of screen freezing. The first being that the screen freezes for like 10 seconds then the screen turns off for 5 seconds then everything is back to normal. The second type is that the screen freezes and just stays like that and I have to hold the power button down to turn it off. Something to note is that this issue has never happened while gaming. I've had multiple 4-6 hour gaming sessions and I never get any problems. This freezing issue mainly randomly happens while browsing the internet, using apps like word, excel, discord, adobe acrobat, zoom etc... I've also performed some CPU and GPU stress tests and haven't gotten any screen freezing during that. Things that I've tried doing to fix this include updating motherboard bios, performing windows memory diagnostic, making sure all drivers are up to date. If anyone could give me some tips on what the problem is or how to go about fixing it would be greatly appreciated.
PC Specs
CPU: Intel Core i7 12700K
CPU Cooler: Noctua NH-D15 Chromax Black
Motherboard: MSI MPG Z690 Edge WIFI DDR4
Memory: G.Skill Trident Z Royal 16 GB (2x8GB) DDR4 3200 CL 16
Storage: Samsung 980 Pro 2 TB M.2 NVME SSD
GPU: Zotac RTX 3050 8GB Twin Edge OC
Power Supply: Corsair RMx (2018) 750 W
Case: Fractal Design Torrent RGB
https://linustechtips.com/topic/1415429-help-please-random-screen-freezing/
Nice system.
Latest bios? Latest chipset and GPU drivers? Windows updated?
Tried with XMP off?
Have you checked what te Windows Reliability Monitor Toll says about the times the issues happened?
It's a good tool to check which software causes issues.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Thanks! Yeah I have the latest bios, chipset and gpu drivers. I have windows 11 and it is updated.
I tried turning XMP off but still got the screen freezing issue so I turned it back on.
I haven't checked that tool yet but I'll make sure to look at it after the next issue.
1 hour ago, EddyG1127 said:
@191x7It just happened again within 5 minutes of turning on my PC ironically I just opened my browser and went to this page and it happened. Attached is a screenshot of the windows reliability log
Hardware error?!
Does OCCT CPU work fine?
3dmark passes?
Temperatures ok?
Hard disk Sentinel says the drive is fine?
@EddyG1127I have the a similar issue. I tried using DDU, Updating BIOS, trying a different PCIe slot, running the system with minimal components, testing memory with MemTest86, re-installing Windows, stress testing the system - temps could be better but not cause of issue, various disk check commands in command prompt, resetting CMOS and turning XMP off, and RMA'd my original card with a replacement and it still didn't fix the problem. Someone on the forum suggested that it could be the power supply but I'm not sure. I just don't know what else to try.
Link to my original post:
Due to my inability to think before I type, I frequently edit my posts. Please refresh before responding!
Tag me @drdrewnatic or quote me so I can see your response.
______________________________________________________________________________________________________________
CPU: INTEL CORE I5-12600K GPU: ASUS ROG STRIX GEFORCE RTX 2070 OC MB: GIGABYTE B660 AORUS MASTER DDR4 RAM: 2X8GB G.SKILL TRIDENT Z RGB 3200 CL16 BOOT: CRUCIAL P5 PLUS 1TB SSD: SAMSUNG 860 EVO 500GB HDD: SEAGATE 2TB 7200RPM PSU: EVGA G3 650W COOLER: THERMALRIGHT PEERLESS ASSASSIN 120 SE ARGO
01101100 01110100 01110100 01110011 01110100 01101111 01110010 01100101 00101110 01100011 01101111 01101101
