help!
Solved by XcatXboy,
7 minutes ago, Middcore said:Make real thread titles instead of just "help."
Describe the problem clearly from the beginning. Right now we only have a vague idea your mouse is lighting up and you don't want it to. What do you mean by "switch to a night setup"? Explain what you're doing in the SteelSeries software, what you expect the result to be, and what's actually happening.
i mean when i switched to night configuration it won't stop lighting i thinked "oh thats weird why i can't switch it?" i tried to edit configurations, not helping
i tried to delete day configuraton, unable to. unplugged an plugged again, helpful as bread to a hungry wolf. so that's when i wrote this post
