Hi
I just bought a used Oculus quest it's gonna come without a link cable
I wanna use it with my pc so I would like to have recommendations of some decently cheap link cables i could use
I saw that the offical one is 100€ thats alot xD its more than half of the entire price of hte headset and its accessories
any ideas?
Thanks in advance
https://linustechtips.com/topic/1412542-link-cable-for-oculus-quest/
If you type Oculus Link Cable into Amazon, there are a ton that are quite well reviewed. Pretty much no one recommends the Oculus branded one. They also don't come with one in the box.
I bought this one but recently I've just been using Airlink or VD.
https://www.amazon.com/dp/B098399X91?psc=1
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
airlink as in using wifi?
how good is that do you actually get good signal/no latency?
oculus quest 1 doesnt have that high of an image quality i can imagine wifi doing the job correctly.
I have a relatively high end Wifi6 access point in the same room so performance near enough that I can't really tell the difference. I wouldn't try it with your basic home router that's on another floor.
the router is in a room next to mine its like 30 ft away and i have wifi 5 i believe
I'll just try it out and see !
