I have several GPUs I use for development. RX 6600XT, RX 560 and GTX960. But I have only two PCI-Express slots, 1 full x16 and 1 full length x4 via chipset.
Now I do need to switch between rx560 and gtx960 frequently (since one supports CUDA and another is GCN GPU instead of RDNA)
I want to install some kind of extension outside the case, so only thing I need to do, power of and swap the cart without opening the case.
There are some "crypto" risers but they low bandwidth x1 instead of x4. I looking for something to make nice cable management and be able to "output" both PCI-E lines at least x4 and power. And some nice connector full x16 outside.
https://linustechtips.com/topic/1412435-pci-e-extension-outside-case/
The closest you can get to that would probably be an external GPU enclosure attached over Thunderbolt. Swapping would even be faster with multiple of these, but that's probably a bit pricey.
The problem with risers is the quality of the connection is often bad and the increased trace length increases latency, possibly error rate and as such decreases bandwidth.
