JLED header on MSI A320M PRO VH PLUS
Solved by Guest,
3 minutes ago, Hesper said:Will it ruin the board just in case something goes wrong? It's kind of hard to buy a new one these days. Thanks again~
I think the lighting will either work or not work. Just follow the pinout and it should be fine.
The rating 3A at 12v means that's what the header is capable of. I don't think the cooler lighting will exceed that.
No, it won't hurt anything on the board. That header has it's own fuse built in.
