hello everyone who choses to read this.
so, my computer has been broken for nearly a year but i got it working for 1 day and after it stopped working the following happened,
my gpu and cpu fan spins but no gpu light without the pcie cable the card is red but with the cable no light sometimes my back fan works other times it doesn't its a asus prebuilt I got a two years ago(I didn't know alot then and linus didn't make the video then) also I would like to add there is no light on the motherboard ethier apart from the rgb(more fps馃槑) and if you need my specs there are
i5 10400f
GTX 1660S
DDR4 8G(I tried multiple sticks 3 with no light one with)聽
ASUS branded prebuilt Motherboard(Dram)
1TB HDD聽
256 Nvme SSD
(Oh also forgot to mention i got no display on my monitor)
Thank you for reading please help 馃檪
https://linustechtips.com/topic/1409299-help/
46 minutes ago, Kaelan lol said:
I seemed to got the pc working but now I see this i somehow got on the update driver and yeah I think the progress bar forze but I don't know聽
Have you tried a different display cable and port like HDMI and DisplayPort?
Also if you have another monitor or tv just to be sure it isn't either one that would help.
Otherwise at this point I think at best your GPU driver is shot. If you can't get it to install properly I would reinstall windows to make all your drivers happy. Then install newest driver for that card.
https://linustechtips.com/topic/1409299-help/#findComment-15244404
Hey sorry! Didn't see this but i didn't actually just stick with that screen for like 20 minutes and it fixed it because the drivers finished installing i could off had drivers from 2020 馃槗
https://linustechtips.com/topic/1409299-help/#findComment-15246557
