2 minutes ago, meeeeeeeeee said:
I have a evga non modular Power supply
probably trash psu then
3 minutes ago, meeeeeeeeee said:
enough info to get cable extensions
i mean extensions are universal so yes they will fit.
my gpu
what exact gpu?
Also extensions arent good for your hardware; longer cables = more resistance = lower voltages. easy math
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1408780-cable-extensions/#findComment-15240412
4 minutes ago, meeeeeeeeee said:
Okay so I have a evga non modular Power supply and I want to know if that’s enough info to get cable extensions for my gpu
You need the precise model number. Btw. you should never use cable extensions in a pc. But you can get longer cables from sites such as cablemod.
https://linustechtips.com/topic/1408780-cable-extensions/#findComment-15240418
Dont see an issue with it. Did it for 2 rigs for a few years. Just build another that has to use them being an sfx psu.
https://linustechtips.com/topic/1408780-cable-extensions/#findComment-15241427
