Help me please.
Solved by Poinkachu,
2 hours ago, Ritzu said:that's not the limit It just happened to hit 80W when I captured it
Well, I don't play that game so I only know as much as I can google around about it.
And based from what I've seen so far, it sounds like that game is CPU intensive, or atleast not GPU demanding.
Perhaps it is best if you look around in that game's forum/community or something and see if it really is CPU / RAM intensive.
If so then yeah, most likely your fps limited because of your CPU / RAM.
Either it's capability, or because it's probably thermal throttling a lot, or both.
