Budget: around £500
Country: UK
Games, programs or workloads that it will be used for: Gaming + schooling
Would appreciate recommendations and help on how to improve it. I'm going to get a 1660 ti when I have saved up a bit more which is why i chose the 5600g and not the x as I have picked no graphics card.
Parts I picked which come to around £515:
Processor+Cooler
AMD Ryzen 5 5600G Processor w/CPU cooler.(£200)
https://www.currys.co.uk/gbuk/computing-accessories/components-upgrades/processors/amd-ryzen-5-5600g-processor-10227696-pdt.html?istCompanyId=bec25c7e-cbcd-460d-81d5-a25372d2e3d7&istFeedId=4d7eb93e-055f-499d-8ee5-1cdcc50d67d1&istItemId=pwpawawxx&istBid=tztx&srcid=198&cmpid=ppc~gg~1022%20(Shopping%20Ads)%20PC%20Components%20-%20Generic~1022%20(PLA)%20PC%20COMPONENTS%20-%20Adaptive%20ad%20group~Exact&mctag=gg_goog_7904&kwid=GOOGLE&device=c&ds_kids=92700065487452860&tgtid=1022%20(Shopping%20Ads)%20PC%20Components%20-%20Generic&gclid=CjwKCAiA3L6PBhBvEiwAINlJ9GjC07aYWt2t5M9KqzcWtCh2L-A4UUsVuDAlN7uBrCkSybFgD2687RoCGWYQAvD_BwE&gclsrc=aw.ds
Motherboard
B550M AORUS ELITE.(£90)
https://www.overclockers.co.uk/gigabyte-b550m-aorus-elite-amd-am4-b550-micro-atx-motherboard-mb-58u-gi.html?gclid=Cj0KCQiA6NOPBhCPARIsAHAy2zDqYHXGIx22KKXd8F4dM8Ovt7aD1SeUZoREDGa2H9nhQrZBb6b8jhMaAlTCEALw_wcB
Storage
Western Digital Blue SN570 500GB M.2-2280 NVME Solid State Drive.(£45)
https://business.currys.co.uk/catalogue/computing/servers-networking/hard-drives/internal-hard-drives/samsung-970-evo-plus-mz-v7s250bw-solid-state-drive-250-gb-pci-express-3-0-x4-nvme/P263251P?cidp=Froogle&gclid=CjwKCAiA0KmPBhBqEiwAJqKK4wd2wmZNkP_Ify_kmRa7suUYXHhbbxmA0aWoYf8PEyWkYttS2sE5RBoCgDUQAvD_BwE&gclsrc=aw.ds
Memory
CORSAIR Vengeance Pro RGB DDR4 3200 MHz PC RAM - 8 GB x 2.(£68)
https://business.currys.co.uk/catalogue/computing/components-upgrades/memory-ram/corsair-vengeance-pro-rgb-ddr4-3200-mhz-pc-ram-8-gb-x-2/N503510W?cidp=Froogle&gclid=Cj0KCQiAip-PBhDVARIsAPP2xc3HPzoyB2If3FM_lRv457251R12gpydM3G7Bp973t0CGwbYmph6ckoaAhsDEALw_wcB&gclsrc=aw.ds
Power Supply Unit
Corsair CX550F RGB Black 80 PLUS Bronze Fully Modular ATX PSU.(£40)
https://www.awd-it.co.uk/hot-deals/corsair-cx550f-rgb-black-80-plus-bronze-fully-modular-atx-psu-cp-9020216-uk.html?gclid=Cj0KCQiAip-PBhDVARIsAPP2xc0PlxzxZ42zu3C60S9wxhMHPaAnFRAho6AQySFsuehnRdwu5d5vkX8aAniJEALw_wcB
Case
Corsair CC-9011138-WW Carbide Series SPEC-05, mid-tower gaming case, Black, Acrylic.(£50)
https://www.amazon.co.uk/Corsair-Carbide-SPEC-05-Mid-Tower-Chassis/dp/B07BH23K53/ref=psdc_430498031_t2_B07PF1TBZF?th=1
System Fans
upHere 120mm RGB LED with Remote control PC Cooling Fan Ultra Quiet High Airflow for Computer Case CPU Cooler,PF1206-3.(£22)
https://www.amazon.co.uk/dp/B0833RLD7X/ref=twister_B0989RZDDW?_encoding=UTF8&th=1
https://linustechtips.com/topic/1407751-first-pc-build-revised/
I would suggest spending 20 pounds more on a higher wattage 80 plus gold power supply, would give a much greater upgrade path for a powerful gpu down the road, especially with a good cpu as 5600g you can use it seemlessly with atleast 2 new generation of gpus.
https://linustechtips.com/topic/1407751-first-pc-build-revised/#findComment-15233492
Thanks, how many watts do you recommend
https://linustechtips.com/topic/1407751-first-pc-build-revised/#findComment-15233523
