Welcome to the forums!!!
What are your system specifications??? You may be able to change the fan speeds in BIOS and set a fan curve, with some motherboards having the option for Auto voltage regulation either for 3-pin or 4-pin fans, voltage or PWM respectively.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1406831-fan-speed/#findComment-15227105
11 minutes ago, Tyler1216 said:
I have a 3pin cpu fan connected to a 4 pin on the motherboard and I don’t know how to change the fan speed.
You need to set it to voltage controlled rather than PWM in the BIOS.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1406831-fan-speed/#findComment-15227109
I tried changing the fan speeds in the bios but it did nothing. I have a asus prime b560m-a ac if that helps
https://linustechtips.com/topic/1406831-fan-speed/#findComment-15227119
Are you sure it's the correct fan header??? Make sure you're adjusting the curve for the fan header that the fan is connected to.
https://linustechtips.com/topic/1406831-fan-speed/#findComment-15227123
Are you wondering if I am adjusting the right fan? I tried all the fans in the bios and nothing slowed down
https://linustechtips.com/topic/1406831-fan-speed/#findComment-15227128
As @Chris Pratt and I previously mentioned, the fan has to set for voltage regulation in the BIOS where you set the fan curve.
https://linustechtips.com/topic/1406831-fan-speed/#findComment-15227132
Go to QFan Control and you should be able to select DC mode from Auto.
https://linustechtips.com/topic/1406831-fan-speed/#findComment-15227136
When I go to qfan control it doesn’t give an option to switch, it just shows pen mode in the top right and I can’t change it.
Edited by Tyler1216
https://linustechtips.com/topic/1406831-fan-speed/#findComment-15227140
When I go to qfan control it doesn’t give an option to switch, it just shows pwm mode in the top right and I can’t change it
Can you take a picture of what you see and post it here???
https://linustechtips.com/topic/1406831-fan-speed/#findComment-15227145
Just now, Tyler1216 said:
Yes
~Snipped~
Set to Manual mode and see if you can change from PWM to DC.
https://linustechtips.com/topic/1406831-fan-speed/#findComment-15227148
