H100i problems!
Go to solution Solved by jscho,
I'd trust the Corsair Link CPU temps. AI Suite (at least on my board) uses a probe next to or under the CPU socket (I think), temps are usually >10 degrees less than actual temps under load. Retarded if you ask me.
Core Temp is what I go by.
[EDIT] Yeah, my CPU temp, according to AI suite, is measured my using a sensor on the board, as opposed to however Core Temp or Corsair Link measures it.
Hello,
I just got my h100i, 750d case and some fans to day. I moved my system over to my new case and installed the h100i and fans and all that. All fine. I boot and one of my fans is REALLY LOUD! It is really loud for 5 seconds when i boot and then it goes down. Why is that? (the fan is a Corsair SP120 and gets power from my motherboard.)
Then I got windows and all updates installed, I installed Corsair link version 2.4.5110. it says my pump on the corsair h100i is running at 2185 rpm. Is this correct? And it says my CPU temp is about 30-32 Celsius while my ASUS AI Suite says it is 19-21 Celsius. Which one should I trust?
post-66974-0-91560200-1397685258_thumb.j
post-66974-0-62012900-1397685127_thumb.p
My rig is:
Corsair 750d case
ASUS P8P67 EVO motherboard
Intel i5 2500k cpu
Palit 570 1 gb ram gpu
Kingston HyperX 1600 mhZ ram 16 gb
Intel 530 ssd 240 gb
Seagate 640 gb hdd
Corsair H100i with to SP120 high static pressure fans
Cooler master 600w 80+ gold psu
https://linustechtips.com/topic/140671-h100i-problems/
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/140671-h100i-problems/#findComment-1878036
Yeah id trust the CL software.
My last asus board i had was a Z77 something or other and i had AI Suit on it.
It often used to tell me my CPU was in the Negative numbers. I live in South Africa and i only have a H100i so there is NO CHANCE of that ever.
See link Below
http://linustechtips.com/main/gallery/image/9192-for-master-chief/
https://linustechtips.com/topic/140671-h100i-problems/#findComment-1898358
