Hello, so i bought a hyper 212 evo v2 cpu cooler, and i insatlled it. I've been on my pc for like 2 hours and now i noticed a weird beep sound coming out from my pc, then it stopped.
But i also noticed that the "pins" or idk what its called on the top of the cpu, out of 8, 4 got deformed, should i be concerned about something or thats normal ?
https://linustechtips.com/topic/1406685-did-i-do-something-wrong-cpu-cooler/
what do you mean... deformed?? Can you take some clean, clear pictures for us to view?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Most likely OP is talking about the way heat pipes are cramped from the factory. This question was quite common few years back.
Just now, Anwee said:
ok, now that makes sense.. I read 4 out of 8 pins and my mind immediately went to EPS 12v cables.. not the heatpipes.
Community Standards
"Beast Mode"
so am i good? , i posted the picture above
Yea, that should be no issue unless for some reason the tube is punctured and the gas can escape instead of recondensing to a liquid.
Community Standards
"Beast Mode"
I have 2 Hyper 212 EVO's on my server and there isn't anything that would cause a beeping sound from the cooler. More than likely the beeping sound was from your motherboard. Do you remember the pattern to the beeps? I.E. 1 long 2 short or 3 short 2 long?
It was just a long high pitched beep , and i heard it after i downloaded obs, after i closed it, it stopped.
now i ran it again and it doesnt do it so idk what could've caused it
Are you monitoring your CPU temperature?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
update : its doing that same weird noise whenever i fullscreen in a game
Edit: whenever i move my mouse around in game while full screened the beep is like moving w\ it, sometimes its lourder sometimes its more silent
So then we can eliminate the cooler, it wouldn't cause that type of problem. Off the top of my head, it sounds like you have some type of electrical short or a loose ground somewhere that is causing some type of electrical interference. I would start by shutting down the system and making sure that everything is connected properly and that all of your cards are seated properly. Then, if the problem continues, start removing 1 component at a time and see if the problem goes away.
Maybe someone else has a better idea of what it could be.
Sounds like coil whine. Could be the VRM on the board or the GPU, could also be your PSU. But since it came after you installed your new cooler, I am leaning towards your mobo VRM's.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
