When should I replace my CPU thermal paste?
Quote
When you see temperatures start to climb that were not normal if the heatsinks/rad are free of dust.
11 minutes ago, diseasedw0rm said:
Also what thermal paste should I use?
MX-4, Noctua NT-H1, Thermal Grizzly Kryonaut, and/or even Arctic Silver 5.
Edited by CommanderAlex
Forgot the 1 on H1
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
4 minutes ago, CommanderAlex said:
MX-4, Noctua NT-H, Thermal Grizzly Kryonaut, and/or even Arctic Silver 5.
don't forget Kingpin KPX
The best gaming PC is the PC you like to game on, how you like to game on it
Sure, you can use that if you want.
Only change your thermal paste if your temps are going abnormally high.
Changing your thermal paste if it's still working fine could get you a few degrees lower than before so it's not that big of a difference.
I would personally go for Kryonaut as it has good results on a lot of benchmarks and comparisons.
NT-H2 is even better. I've used it over Kryonaut recently. Spreads better, if you use dot method.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
How will I know if my temps start dropping? Or should I just start checking them like every month or a few times every month or something?
Well, they should be rising. Check in sensor monitoring software like HWinfo64 or MSI Afterburner while in game. I personally have MSI Afterburner on in the top left corner with sensor readouts for CPU temp. If you're going with a quality thermal paste, it should last at least 2 years before having to repaste. For cleaning in between, depends on what environment your PC is in. If it is really dusty, expect to dust the heatsink and filters more often.
Clean your intakes at least once a month and you should be fine for a long time.
