PCPartPicker Part List
CPU: Intel Core i7-12700 2.1 GHz 12-Core Processor  (€374.95 @ Azerty)
CPU Cooler: Noctua NH-U12S chromax.black 55 CFM CPU Cooler  (€69.90 @ Amazon Netherlands)
Motherboard: MSI PRO Z690-A DDR4 ATX LGA1700 Motherboard  (€200.99 @ Paradigit)
Memory: Team T-FORCE VULCAN Z 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  (€143.90 @ Azerty)
Storage: Sabrent Rocket 4.0 2 TB M.2-2280 NVME Solid State Drive  (€269.99 @ Amazon Netherlands)
Video Card: Inno3D GeForce RTX 3080 Ti 12 GB iChill X4 Video Card  (€1899.00 @ Azerty)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (€98.95 @ Amazon Netherlands)
Power Supply: SeaSonic FOCUS GX 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (€159.90 @ Azerty)
Monitor: ViewSonic VX2758-2KP-MHD 27.0" 2560x1440 144 Hz Monitor  (€279.00 @ Amazon Netherlands)
Keyboard: Corsair K70 RGB MK.2 Wired Gaming Keyboard  (€155.99 @ Megekko)
Mouse: Razer DeathAdder Elite Wired Optical Mouse  (€74.98 @ Amazon Netherlands)
Total: €3727.55
Generated by PCPartPicker 2022-01-21 00:22 CET+0100
Little under budget so you can splurge on more ram or SSD storage if you want.
https://linustechtips.com/topic/1405404-first-build/#findComment-15218253
Since i decided to use my laptop as keyboard and screen i only need the computer itself to function as gaming power.
My laptop isn't really designed for gaming.
So i now have the following:
-Asus Prime Z590a-A
-4X Trident Z Royal
-Be Quiet! Dark Base 700
-Be Quiet! Silent Loop 2 240MM
-Samsung 980 1TB
-Asus TUF gaming Geforce RTX 3070 TI OC edition
-Intel Core I9 10900K
-Be Quiet! Straight power! 1200W Platinum
I do want this build to be as silent as can be, as it's going to be in the living room.
Any Suggestions?
https://linustechtips.com/topic/1405404-first-build/#findComment-15219517
