Okay, whenever  Itry to connect to a server on DayZ it always says "Bad version, server rejected conection" What can I do to fix this?
I also have arma 2 and the arrow head, but it says the other 2 ones in the corner.. could that be the problem?
Diamond 5 in League :)
https://linustechtips.com/topic/140317-arma-2-day-z-problems/
What launcher are you using if any? do you have the expansion installed? Are you playing throuh the steam version of the DayZ mod?
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/140317-arma-2-day-z-problems/#findComment-1872515
Make sure your running the same version of dayZ as the server, NOT epoch or namalsk ect as you most likely dont have them installed.  What arma version are you running (it says in bottom right on main menu).
Try these two launchers though (dayz commander is better IMO). (you will have to re-download the mod)
http://www.dayzcommander.com/#download
http://withsix.com/
https://linustechtips.com/topic/140317-arma-2-day-z-problems/#findComment-1872555
http://withsix.com/
THIS.
Using steam launcher is useless as it is outdated. I recommend dayz commander because it does the updating job for you.
Gaming Computer | Case: CM Storm Scout II | MB: Asus P8Z77-V LK | CPU: i5 2320@3,6ghz | GFX:  MSI GTX 770 Gaming | RAM: 8gb DDR3 @ 1333mhz | Storage: 1TB Seagate Barracuda | Monitor: 1x Asus VG248QE @ 144Hz , 1x Samsung SyncMaster SA300 @ 77hz OC'd
Other Device's | Phone: Samsung Galaxy S3 LTE@OmniROM | Tablet: Samsung Galaxy Tab 2 10.1@OmniROM | Laptop: Lenovo ThinkPad T61 Win 8.1
https://linustechtips.com/topic/140317-arma-2-day-z-problems/#findComment-1872578
