corsair link problems....
Go to solution Solved by adriel604,
This exact same thing happened to me too recently.  It just decided to not show any of my fans anymore for me to adjust.  After numerous re-installs it still was not working.
What I ended up doing was uninstalling it altogether and going with a fan controller instead.
My computer boots twice as fast now and I can easily control all my fans.  I hate Corsair Link.  I feel like Corsair has put this on the shelf and they have no more plans to update it .. I actually regret buying an h100i now.  I wish I got the h220 instead :(
Hey guys i could use some help, corsair link has decided to go crap itself and i have tried reinstalling it doesnt want to work anyways below is my problem:
a few notes:
My fans are still running and so is the pump
also the USB plug is properly plugged in
im running windows 8.1 (which i think might be the problem)
if anyone knows the solution that would be amazing if you could help!!
https://linustechtips.com/topic/140245-corsair-link-problems/
https://linustechtips.com/topic/140245-corsair-link-problems/#findComment-1871481
oh i see :/ well that sucks i hope they do update it, gives me much better control then my base motherboard curves do :/
https://linustechtips.com/topic/140245-corsair-link-problems/#findComment-1871826
Its just a Link problem, some people have been able to get it working temporarily by reinstalling and if you just leave it youll find that it sometimes works. I called Corsair and they basically said RMA your unit and you know what. That didnt do a thing. Also i probably need to specify its a problem between Link and Windows 8 in particular.
I just set up a fan profile in my BIOS. Both the front intake and the two top ones scale from 50-100% from 45-65oC So that i never have negative pressure and the great thing about BIOS fan control is that you can be running Hackintosh or Linux even windows and not have to worry about starting a program or adjusting a knob when you think your processor is hot.
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/140245-corsair-link-problems/#findComment-1871846
true, honestly all i want is to fix my LED on my H100i which is stuck between orange and a really weird fade to off
https://linustechtips.com/topic/140245-corsair-link-problems/#findComment-1872048
If you mess around with plugging in and unplugging and quitting the software and starting the software eventually it will run. When ever i want to change the light on mine thats what i have to do.
| F@H STATS |
https://linustechtips.com/topic/140245-corsair-link-problems/#findComment-1872072
lol I only used corsair link to change my LED as well. Now it's just at blue.
When you've exhausted your options look into a fan controller :)
https://linustechtips.com/topic/140245-corsair-link-problems/#findComment-1872075
