1 hour ago, FilipSebik said:
Get the prusa. It's the best 3D printer you can get under 1k, although I don't know if your budget is 1k euros or dollars, but anyways, the prusa is best, cause it just works
okay thanks and do you have any idea how difficult it is to assemble
