i am using recently the code runner names extensions to quickly open the terminal window inside the vscode app and run the c programm that i mad. but it seems like whenever i use scanf or any other functions or statements like if else or nested if else the extension is unable to execute the code. but if manually use the gcc command to compile and make the .out (executable) code the code runs fine without any error.
anyone saw similar behaviour with the extension as me? share your experience if you are using the extension.
https://linustechtips.com/topic/1400814-extension-in-vscode-problem/
The result of code runner should show in the code output tab (Ctrl+Shift+U)
What is shown when you are running code runner (Ctrl + Alt + N).
Code runner should output command similar to this
[Running] cd "/full/path/to/project/" && gcc filename.c -o filename && "/full/path/to/project/"filename
... output displayed here ...
[Done] exited with code=0 in x.xxx seconds
