is the bios up to date that would allow that CPU to even get into the bios? Are you using a known good HDMI cable? Are you getting any errors on the mobo
https://linustechtips.com/topic/1400629-help-again/#findComment-15184541
You need to plug in the CPU power cable.
https://linustechtips.com/topic/1400629-help-again/#findComment-15184543
