Error code 8, no post
Go to solution Solved by szdawid2,
Just now, GarrisonD said:
Luckily I did have a laptop laying around and used the ROG flashback and BOOM she posted. Guess I should鈥檝e followed that bit of online advice but this is the first motherboard I鈥檝e owned with that feature. Thanks again for the replies聽
No problem. 馃檪
Hello,
I recently purchased parts to build a new PC but am running into some problems. To ensure my new parts work I used the tried and true motherboard test bench setup but after socketing my ram and cpu and connecting it with my power supply I cannot get it to post. I have an ROG crosshair vii so I can see the boot codes but all I get is code 8 (not 08 just 8). After doing some browsing I鈥檝e found all sorts of people with the same problem but none of their solutions have worked. Any help would be greatly appreciated.
Build specs:
CPU: Ryzen 5800x
Motherboard: ROG crosshair vii
ram: 2x16 Corsair 3600
psu: Corsair RM1000
https://linustechtips.com/topic/1399542-error-code-8-no-post/
That was the first thing I tried before posting here but just tried it again to make sure and got the same result聽
Do you have another power supply? If yes, then try it and see if it works, otherwise one of your parts is dead. 馃槥
https://linustechtips.com/topic/1399542-error-code-8-no-post/#findComment-15177254
Dead board is what I was leaning towards. The power supply came from an existing build and was working completely fine before聽
https://linustechtips.com/topic/1399542-error-code-8-no-post/#findComment-15177261
8 minutes ago, szdawid2 said:
btw can you make my answer a solution, I'm trying to bump up my level, because I know many things about computers and I will help. 馃檪
I鈥檓 leaning towards dead board but not sure of that yet. Other people have said the solution is bios flashback聽
https://linustechtips.com/topic/1399542-error-code-8-no-post/#findComment-15177283
ROG boards have a spot in the back to flash new bios聽
You could try it, but you need another PC, if you have one, then try it, maybe it will post. This error code is pretty weird so I really don't know what's the fix for it, but if you want to, then try it. 馃檪
https://linustechtips.com/topic/1399542-error-code-8-no-post/#findComment-15177299
https://linustechtips.com/topic/1399542-error-code-8-no-post/#findComment-15177341
No problem. 馃檪
https://linustechtips.com/topic/1399542-error-code-8-no-post/#findComment-15177343
