4 minutes ago, Hewie said:
USB will run at the slowest speed in the link so it should work fine however it will be limited to usb 2.0 speed!
Realistically that should be fine if it's just for controller inputs
I also used another adaptor and it still doesnt work
https://linustechtips.com/topic/1398884-usb-hub/#findComment-15173286
That should work no problem then =D
USB is very backwards compatible!
I wanted to get a hub adaptor with internet cable hdmi usb ports and charging ports and i found one and my dad was like i have a usb hub and it is working on my computer but probably its only for computers and laptops only that hub
https://linustechtips.com/topic/1398884-usb-hub/#findComment-15173289
