I'm planning on buying a new case and cpu cooler, the corsair obsidian 450D mid-tower and H100i. Of course I'm gonna place 2 front intake fans, 1 exhaust at the back and 2 corsair sp120's on the h100i. The H100i will be placed in the case 'ceiling?'
My questions are:
CAN I  actually switch the standard fans which come with the H100i to the sp120's ?
Do I still need the CPU fan header?
Can I connect the 2 sp120's which are on the H100I to the CPU fan header and CPU opt fan? (In that case I'll obviously still need the cpu fan header) Or Do I connect those to normal system fan headers?
Can all my fans be controlled by temperature through corsair link? I'll be using 5 SP120's which only have 3pin connectors
PS: My mobo only supports 3 system fans
https://linustechtips.com/topic/139805-5-fans/
yes
yes
CPU OPT fan header i believe
dont think so i dont think that they are PWM fans
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/139805-5-fans/#findComment-1865083
Got any software which allows me to control fan speeds?
the fans have to be PWM or 4 pin fans for you to control the speed @xxMichael has that set up and he can help you more than i can, since i dont have this setup but he does
https://linustechtips.com/topic/139805-5-fans/#findComment-1865374
I can manually control the fan speed, I'm sure of that because I've done so with Gigabyte Easytune, but I really don't want to use that software, rather something simple, lightweight that easily allows me to just control my fan speed and maybe temps of cpu etc
https://linustechtips.com/topic/139805-5-fans/#findComment-1865384
I also am looking for software to control fan speeds.
Case: Carbide 300R
CPU: i5 4690K @ 3.90GHz
RAM: 8GB DDR3
Mobo: MSI Z97-G45 Gaming
GPU: R9 290 Tri-X
PSU: EVGA SUPERNOVA NEX650G
Storage: 4TB NAS
Drive 1: Seagate 1TB 7200RPM
Drive 2: WD 500gb 7200RPM
___________________________
Keyboard: Vengeance K50
Headset: Vengeance 1500 V2
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/139805-5-fans/#findComment-1865462
If you want to control all fans easily, I reccomended plugging all the case fans into a fan controller, it doesn't get more simple than that really, however plug the h100i fans into the CPU header.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/139805-5-fans/#findComment-1865541
My questions are:
your h100i should have a 2 way fan splitter i believe, plug those to the 2 sp120s and into the cpu fan header.
you can find another 2 way fan splitter to plug both front fans into the sysfan header.
last fan into the last fan header.
or otherwise use a fan controller for the 2 intakes and exhaust
for software you could try using speedfan to control fan speeds.
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
https://linustechtips.com/topic/139805-5-fans/#findComment-1868417
