PBO settings - Help
3 minutes ago, j4j_0 said:What would you recommend setting the EDC value to?
I think the default EDC limit is 140A for your CPU, so by limiting it to 150 you're already allowing it to take more than it would stock. Now the question is: why does increasing the limits stop your CPU from crashing? I think just enabling PBO also increases the voltage slightly, so the system is doing the 2nd part of my recommendation on its own. So it's not the limits that help your CPU, it's the voltage boost.
If you want to try different EDC values, I'd recommend decreasing in steps of 10, until you get to 100, any lower is not going to help for sure, if it doesn't work at 100 then this is not the problem. Bumping the voltage seems more likely to help, or you can try finding a setting called "LLC" or Loadline Calibration, and change it to a very low level, i.e. 1 or 2. This should help stabilize the voltages when there is load.
