High 5800x Temps
Solved by GuiltySpark_,
1 minute ago, PointFive said:Do you mean the fan or the pump curve?
Because for the pump, its at max (Extreme for corsair). For the fan I think is already decent because it basically kicks into 100% above 65C.
I think it just might be limited because its a 240mm aio. But I don't know and just want to make sure I don't have a faulty CPU nor AIO.
CPU is fine, AIO is just marginal for a chip on the level of the 5800x.
Curve Optimizer:
