2013 Macbook Pro won't charge....Dead battery?
79wjd
I think the battery in my 2013 Macbook Pro is finally completely dead. It's been in the "replace" stage for several years at this point and has over 3k cycles on it, but starting this morning it will no longer charge at all -- it will work plugged in though. I'm assuming the issue is a shot battery and not a bad charging circuit, but is there any way to confirm that? If it's just a bad battery, I might consider replacing it, but if it's a bad charging circuit, well...I'll probably just upgrade to a new 14" MBP.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
