Best place to put intake fan?
Solved by Hairless Monkey Boy,
If you are adding just one fan to the front, put it in the middle position. That way the airflow will reach both CPU and GPU.
Edit:
Looking at the pictures, it seems the case has a solid front panel. Consequently, a single front fan is more likely to circulate internal hot air through the remaining empty fan holes than it is to pull in fresh air. Instead of getting a single Noctua fan, consider getting three Arctic P12s to fill out the front. That way you'll be getting more fresh air into the case.
