Case compatibility questions
Go to solution Solved by MegaDave91,
Yes, yes for the first two
Took a quick glance and didn't see any other windowed case ~$100 on that website.
will this case fit; http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_547&products_id=20008
1: a h100i?
2: a cooler master hyper 212 evo?
also is there a better case sub 100aud that has window, compatibility for one of those coolers? thanks
In the grim darkness of the far future, there is only a GTX 1080, just a single 1080, where my glorious PC once stood....
For that is all I need, For the Emperor of Man, Jen-Hsun Huang, protects. We march for Nvidia, and we shall know no fear!
https://linustechtips.com/topic/139567-case-compatibility-questions/
1:yes 2: yes
Christian and Proud of it
Please read the CoC        My Build Log
1:yes 2: yes
thanks for the quick replies  :)
doesnt say shinobi under bitfenix for h100i...
Aww sheet. Here we go.
--snip--
wrong case, thats the xl version. i linked the smaller one
Apologies, OP.
nono its ok you were just trying to help. i appreciate it :)  though the others say it will fit so its fine  ;)
