First PC Build
Go to solution Solved by Chris Pratt,
The 3700X is a good CPU but a bad value at $329. The 5800X was going for around the same price, but it looks like it crept back up to $400 again. However, the 5600X is cheaper and would have about the same horsepower due to gen on gen improvements, with better single core performance to boot. You might also consider the 12600K. It's an excellent value at $299, and will beat the pants off the 3700X, assuming you can find a reasonably priced LGA1700 board with DDR4.
If you do keep the 3700X, you should get faster RAM, at least 3600MHz CL16. It's a multiple CCD design, so while 3200MHz isn't horrible, you are leaving perf on the table by slowing down the FCLK.
The H510 case needs to go. It's thermally awful. With the components you have currently, it would be okay, since both the CPU and GPU are relatively low powered, but if you ever upgrade to anything better, you're going to regret that case quick.
Budget (including currency): 1500USD not including peripherals
Country: America
Games, programs or workloads that it will be used for: Fishing Planet is really the only PC game I’d play, It would be mostly used as an intermediate between my Xbox for streaming
https://pcpartpicker.com/list/vZzwMv
What do I need to change
https://linustechtips.com/topic/1395432-first-pc-build/
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1395432-first-pc-build/#findComment-15151652
yo buds can i use sd card for my first pc build  im planning with this cheap hardware specs: intel core 2 duo e8400 (i forgot my thermal paste) 2gb ddr2 ram 600mhz  (dont have graphics card?) intel g31 potato graphics inside acer eg31m v1.0 motherboard (no case? hehe cheap )  (ssd :X)   (hdd:X) (use sd card from ur old nokia:✓✓✓) but my mama buy me a very cheap psu (mama says: you use it or i throw my slippers on you ) guys can you answer me it will blow or run minesweeper (i will install windows xp lite on it looks fun btw did you know im 12yrs old)
https://linustechtips.com/topic/1395432-first-pc-build/#findComment-15151708
https://pcpartpicker.com/product/bCYQzy/corsair-4000d-airflow-atx-mid-tower-case-cc-9011200-ww Will this case do any better?
https://linustechtips.com/topic/1395432-first-pc-build/#findComment-15151746
45 minutes ago, JeremyBradshaw said:
Yes. The 4000D is excellent.
https://linustechtips.com/topic/1395432-first-pc-build/#findComment-15151807
