Hey guys
Something wierd is going on with my pc. It is freezing and restarting automatically while gaming. I tried reinstalling drivers and windows. Yesterday while i was gaming pc totally froze and restarted. When I opened discord pc froze again and this time it didn't restart. So I force shut down it and tried restarting. It got stuck on booting bios. Again I restarted it and this time there's no display. The computer turns on, all the fans are spinning, monitor is also fine, but there's no booting screen on anything. Anyone know how to fix this?
(Specs are
I5 10400,
16gb (8× 2) ddr4 ram,
1TB hdd,
Gtx 1060 6gb AMP,
MW 450w Cooler master PSU,
B460m Aorus pro mobo)
Thankyou
https://linustechtips.com/topic/1395213-a-little-help-here/
If you built the pc yourself check for loose connections.  Heck, if you know how check anyhow...
It could be an overheating issue.   Make sure you have enough fans pulling/ pushing air through the case.  Make sure your desktop / tower is not in a confined space
If placed on the floor and had a bottom mount PSU make sure carpet is not restricting air flow from the bottom causing PSU to over heat.
https://linustechtips.com/topic/1395213-a-little-help-here/#findComment-15150175
