I bought a 750w ROG STRIX a
ASUS Gold power supply, to power up my x570-e gaming asus motherboard, the problem is next: The motherboard accepts 8+4 pin cable, while PSU got 4+4 pin cable, do i have to buy a new PSU or there is an adapter, it's necessary to atleast power 8 pin port on motherboard
https://linustechtips.com/topic/1394902-i-got-a-problem/
Put the 4+4 connectors together and it makes an 8 pin connector. The ROG Strix 750W PSU comes with two 4+4 cables so if you want to plug in the extra 4pin connector as well just use one of the 4pin connectors from the second CPU power cable.
https://linustechtips.com/topic/1394902-i-got-a-problem/#findComment-15148093
I got myself a 8 pin cable and ill use the one of 4+4 for the overclocking connector
https://linustechtips.com/topic/1394902-i-got-a-problem/#findComment-15149511
