Budget:1100-1200 Euro
Country: Greece
My current pc is getting old(i7-6700 non k,16gb of Ram,500gb m.2 and a 1070)
I was thinking of buying a new cpu,ram,mobo,cpu cooler and m.2 combo
New build:
Cpu:Intel Core i7-12700K 2.7GHz 445€
Ram:32 gb 3600ghz 165€
Cooler: Noctua Nh-u12a 125€
M.2: Samsung 980 pro 1tb 175€
Mobo: Gigabyte Z690 gaming x. 220€
Gpu:Will use my old gtx 1070
Psu:I already have an Rmx 750x
Case:My current case
Should I get a new GPU "3070 or 3060ti" with the same money and don't upgrade cpu?
The 3070 costs 1100 -1200€ in my country atm
I have two 27' 1080p  144 hz monitors
Any advice?
https://linustechtips.com/topic/1394649-pc-upgrade-help/
If you plan on doing other upgrades (GPU) in the future I'd buy what you already listed, just a different SSD because Samsung is overpriced. Kingston A2000 or WD SN750 should do, also you may be able to use the current SSD for the OS and the new for extra storage.
If you don't plan on upgrading just get a better GPU, maybe a 6600 XT (performance between 3060 and 3060 Ti) or 6700 XT (performance slightly better than 3060 Ti)? They generally have a better value than Nvidia cards.
https://linustechtips.com/topic/1394649-pc-upgrade-help/#findComment-15146195
Country: Greece
New build:
Any advice?
I suggest something around the range of this, as the 1070 is still a somewhat capable card, and most games will be CPU bottlenecked
PCPartPicker Part List
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($299.99 @ B&H)
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler  ($37.99 @ Best Buy)
Motherboard: ASRock Z690 Pro RS ATX LGA1700 Motherboard  ($179.99 @ Newegg)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($75.99 @ Best Buy)
Storage: Samsung 980 500 GB M.2-2280 NVME Solid State Drive  ($64.99 @ B&H)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($46.99 @ Best Buy)
Case: Cougar MX340 ATX Mid Tower Case  ($59.99 @ B&H)
Power Supply: EVGA SuperNOVA GA 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($59.99 @ Newegg)
Case Fan: ARCTIC P12 PST 56.3 CFM 120 mm Fan  ($8.99 @ Newegg)
Total: $852.89
Generated by PCPartPicker 2021-12-09 09:40 EST-0500
https://linustechtips.com/topic/1394649-pc-upgrade-help/#findComment-15146201
I'd say going with your current upgrade plan would be a very nice feeling upgrade. Everything will feel snappier and games will feel smoother. Only upgrading the GPU would give you higher frame rates, but might feel a bit of stutters and frame drops due to having an older CPU. Of course, this depends on the games you plan to play.
https://linustechtips.com/topic/1394649-pc-upgrade-help/#findComment-15146533
