Please help
Solved by Joe_mac154,
I solved the problem, the windows install on it was definitely bugged for some random reason, the ssd was too full to be able to do a clean install of windows and we couldn’t delete anything from the drive because of the previously mentioned problem. We went to bestbuy and got a new ssd and loaded windows onto it to replace the old one everything works fine and he got a small upgrade out of it lol. Thanks for all the suggestions and help!
