So i need an LED strip. I've been buying some from an off-brand and they keep dying. If BitFenix still has theirs i would love to just use theres but if you have another favourite that would be fine too.
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/139450-best-led-strip/
Can i cut those. Like if i get a 600mm can i cut it to 450mm
| F@H STATS |
https://linustechtips.com/topic/139450-best-led-strip/#findComment-1859568
Yes they can be cut down and rewired if desired at specific cut points, but they come in different lengths to fit most needs with pre wired connectors to make things easier to daisy-chain, and connect.
https://linustechtips.com/topic/139450-best-led-strip/#findComment-1859679
I've got some blue strip from a friend in my Z11. He used those on his car, until he got himself a decent fine...  :D
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
https://linustechtips.com/topic/139450-best-led-strip/#findComment-1862187
