I have no idea which part of my build is giving me these graphical glitches... I've read online that when purple/green appears it's an indicator of a bad GPU...? My exhaust case fan on the back is spoilt so I manually spin it with a stick everytime I boot up my PC (thankfully it continues spinning after that) so could it be a case of GPU being thermally throttled? Here are some screenshots for reference. Since I bought my pre-built system from a vendor I can't RMA my GPU directly from the manufacturer, and my 3-year warranty with the vendor has expired.
CPU: Intel i5-8400
Cooler: Intel stock air cooler
MOBO: ASRock Z370M Pro4
GPU: Nvidia Geforce GTX 1060 6GB
RAM: 1 x 8GB ADATA 2400 mhz
SSD: 120GB KLEVV NEO N600 M.2
HDD: 1TB Toshiba DT01ACA100
PSU: EVGA 450w Bronze+
OS: Windows 10 64-bit
BIOS: P1.40
  • 4 weeks later...
On 12/5/2021 at 1:55 AM, Pixelfie said:
Could also be RAM. Since it's a single stick you can try running memtest
For the fan issue, try clearing CMOS
Hey, thanks for the reply! I've ran memtest and the RAM seems fine. As for the fan issue, I've cleared CMOS but it still isn't spinning 😕 I guess it's just a faulty fan then.
