I have a pc with a 1070 Msi and intel i 5 8400k and nzxt z53 aio on a ASU’s prime z370p and I did have a Corsair rm550x but it’s blew a few days ago so I replaced it with a Corsair rm650x now when I power my pc it’s says cpu fan error so I loaded the bios and my cpu just get hotter it won’t cool and it’s only in the bios any advice guys ?
https://linustechtips.com/topic/1392928-cpu-overheating-help-please/
Cpu fan error means that low or no fan rpm is detected from the cpu_fan header. Check and make sure that something is plugged into that fan header and that the cooler pump and fan are spinning.
Moved to Cooling.
Your AIO is either:
A: not hooked up to your mobo properly, or
B: it died
EIther way, double-check your connections. If you don't find anything, try replacing your cooler with a cheap air cooler for testing.
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
1 minute ago, Kid.Lazer said:
Your AIO is either:
B: it died
If it died would my pump head still light up is light powered by the usb or the sata
The lights and motor are very likely electrically independent. If the motor burned up, or is seized, the lights would still function.
Primary Gaming Rig:
HTPC/Gaming Rig:
If you destroyed a PSU, there's no telling what other devices it took down with it.
Primary Gaming Rig:
HTPC/Gaming Rig:
11 minutes ago, Cuss123 said:
Everything seems to be fine I can boot in to windows just it’s won’t cool so I can’t go on it not until I can get it to cool it’s madness
What temperatures are you seeing? Were you having any issues before the PSU failure?
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
No problem before the psu and it got to 75 in like a few mins so I turned it off
75c is fine for load and the system should shut down if temps are too high. What are load temps? I usually use a stress test like OCCT.
Not when before it never went pass 45 I mean just keeps going to 90 my pump rpm in 4600 can the pump still be dead
The pump probably isn't dead if it's spinning. Have you tried reseating the cooler? What's the thermal paste spread look like?
Fixed it and I was a stupid fix I just had to take the radiator out and put it bellow the pump and then above it and it started working if anyone else has same problem try this before you buy a new one I was about to then I tried this 😊
