What is the cord called that goes from the PSU to the laptop, they do sell them separately right?
GIGA AORUSBYTE B550I PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 32GB (2 x 16GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
https://linustechtips.com/topic/1392655-power-bricks/
Power adapter, AC adapter, power brick. It would be easier to know the specific laptop in question then you can just look up the power adapter model number to find a replacement.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1392655-power-bricks/#findComment-15132312
its the power supply... or power brick...
Usually you can get those as spare parts original or third party...
For example in our company, we got a bunch of refurb Lenovo Thinkpads with docking stations, but only one power brick...
SO I needed to get at least one more power brick per Laptop... Original lenovo 70 bucks +, Lavolta third party 20 bucks...
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/1392655-power-bricks/#findComment-15132314
