5800x overheating
Solved by GuiltySpark_,
1 minute ago, flairclapper said:
I undervolted my cpu
Completely revert everything you've done to the board. Better yet, clear the CMOS and start fresh. If the PC was given to me, i'd re-do the thermal paste application and more importantly the cooler mounting myself then boot up and run only HWInfo or Ryzen Master for checking temps.
Regarding the MSI AIO, those are dying weekly around here, absolutely terrible unit so no surprise there. The FUMA 2 on the other hand is a very competent air cooler.
You have two likely scenarios and another very unlikely scenario. First, your mounting method and airflow is extremely bad.
Second, a sensor onboard the die is bad. This is very unlikely.
