10 hours ago, CyanideDaydreams said:
How do I use the GPU on pytorch instead of the CPU?
First of all, is your GPU even supported?
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
Which system are you using? After installing nvidia drivers and all of the cuda environment you should be able to follow the guide posted by @Sauron and get everything working,
Lenovo N23 Yoga
