Budget (including currency):1250$
Country:US
Games, programs or workloads that it will be used for:Play new and upcoming games ,Streaming games/Recording games(1080p 60fps),Video editing,Programming.
Other details:I will be playing all games on 1080p 60 fps.And I have gathered a list of parts that I think is enough.All I need is validation if these parts are okay for their purpose.And also I will be using nvenc for recording and streaming.I will be adding more monitors in the future(1080p 60fps).And I wont be buying online.
3060ti
Ryzen 5 3600x
Ballistix 16gb(8×2) 3200Hz white
MSI b550 pro VDH
Asus strix 550w
Nzxt h710
Toshiba p300 2TB
Intel 660p 512gb SSD
https://linustechtips.com/topic/1392007-first-pc-build-help/
It should work, though you're probably better off getting a different CPU/motherboard. The i5 11600k is selling for $230 on Amazon (last I checked) and even less at Micro Center, which is only ~$20 more than the 3600X should sell for, and performs a lot better.
https://linustechtips.com/topic/1392007-first-pc-build-help/#findComment-15127675
Thanks,But doesn't AMD have other great features here.Like cpu temps and Ram speeds
https://linustechtips.com/topic/1392007-first-pc-build-help/#findComment-15128374
If you're going to do video editing, streaming/recording and similar maybe a Ryzen 7 3700/3700X or a Ryzen 5 5600/5600X would be a better choice (if it fits your budget), as well as the motherboard if it can fit in your budget the Gigabyte B550M Aorus Pro is a great choice.
CPU: Ryzen 9 7900X | CPU Cooler: Thermalright Phantom Spirit 120SE | Mobo: Asus TUF Gaming B650 Plus | RAM: Kingston Fury Beast 32GB DDR5 5600mhz | GPU: Asus TUF RX7800XT | PSU: Cooler Master V850 V2 Gold | SSD: Kingston Fury Renegade 1TB M.2 NVME  | HDD: WD Blue 1TB x2 | HDD: WD Blue 2TB | Case: Fractal Design Pop-Air XL
https://linustechtips.com/topic/1392007-first-pc-build-help/#findComment-15129281
