I recently bought a corsair virtuoso and let me tell you that icue sucks so bad. i knew it sucked before i used it but this is just insulting. The presets suck and sound garbage, the lagg on discord is anoying as hell. i can go on for ages on end but i just wanted a replacement for icue and i dont care about the rgb, thats the only replacement i can find. i just want something for the sound any ideas?
Cuz corsair is not going to fix this ive seen posts about this from 2 years ago. F**k you corsair i wasted 200 dollars on this
https://linustechtips.com/topic/1391836-replacement-for-icue/
2 minutes ago, smokion said:
Sound profiles it sounds like sh*t on defult and when you uninstall it it doesnt save the profile
What if the program is installed but not running? (turn off start with Windows)?
Also what is your Icue version? Windows fully updated?
https://linustechtips.com/topic/1391836-replacement-for-icue/#findComment-15126552
Everything is updated and if the progra mis closed it sounds trash again so you need it open
https://linustechtips.com/topic/1391836-replacement-for-icue/#findComment-15126646
