Wifi problem
Go to solution Solved by TheSLSAMG,
You should try PowerLine.
Hi Forum!
I recently built a gaming computer which I have been very satisfied with, although I experience lag due to my routers positioning. Currently my router is in our basement (which is very dumb I know) but I'm unable to move it because of many reasons regarding my brother and father. Right now I play upstairs. So my question is, what would a better buy be to improve my lag, a wireless repeater or another router? If i was able to put a repeater or router on the first floor, which one would improve my situation? I hope its clear that moving my first router out of the basement is not an option.
https://linustechtips.com/topic/139149-wifi-problem/
Hi Forum!
get another router with better wifi and put it closer to ur room ?. or just buy 40feet of ethernet cable and run it downstairs ?
https://linustechtips.com/topic/139149-wifi-problem/#findComment-1855295
https://linustechtips.com/topic/139149-wifi-problem/#findComment-1855299
