Hello all,
Just built a new pc. Trying to figure out how to use the 4tb mass storage drive I have, and found an article on dummies going through how to do it. Problem is, there are two uin-allocated spaces for the one drive, and I can't figure out how to combine them.
Help? thanks
https://linustechtips.com/topic/1390892-setting-up-hdd-for-pc/
You can just manually delete the partitions, quick format, then create a new simple volume.
This is assuming there’s no data on the drive that you want to keep.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1390892-setting-up-hdd-for-pc/#findComment-15120157
Where at? I cant find the option do do that
https://linustechtips.com/topic/1390892-setting-up-hdd-for-pc/#findComment-15120302
Windows Disk Management. I’m not at my computer right now, but you should just be able to right click on the partitions and delete them.
https://linustechtips.com/topic/1390892-setting-up-hdd-for-pc/#findComment-15123062
