Does anyone know of a preferably 60% or TKL wireless keyboard that can connect to multiple devices either by having two separate dongles or switching between a dongle and BT? I can’t use a typical BT keyboard since one of the devices I’m using is an Xbox. Alternatively I’ve thought about using a kvm but is there a cheap remote activated one? Having a push button on the unit wouldn’t work since this will be behind my media console.
https://linustechtips.com/topic/1388654-looking-for-multi-device-wireless-keyboard/
42 minutes ago, huilun02 said:
K380 or K480 or MX Keys Mini
And a bluetooth dongle for whatever device lacks bluetooth
If you want it to come with a dedicated non-bluetooth dongle while still being multi-device, I dont think Logitech has a 60%/TKL option
Probably the closest match is the K580
Dont know anything beyond Logitech sorry
Good luck
The 380 was a pick I was looking at, but didn’t even think of using a dongle. Do you know if the Series X supports using a USB dongle? I know it doesn’t have innate BT support. Thanks for your help!
Keychron kbs, Anne Pro 2, Apple Magic Kb.
All of them can have separate devices on wired and bt (unlike others Apple has only one bt memory slot)
Think if you are willing to go wired only on all devices, might be easier to get two cables instead, with a much larger selection of kbs
