2 hours ago, TheWeemy27 said:
How Long Can A HDMI 1.3 Cable Be, Before i start noticing Latency.
The issue isn't latency but signal degradation. There's a recent LTT video where he tested a crap load of HDMI cables, and basically, anything over 6ft, you need optical HDMI or you're going to have a bad time.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1387616-hdmi-max-length/#findComment-15096252
The video was about HDMI 2.1, that does not apply for other HDMI versions.
HDMI 2.0b can easily go over 10m (30ft) even without using optical cables.
HDMI 1.3 can realistically go to around 30m using standard copper cables. (100ft)
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1387616-hdmi-max-length/#findComment-15096565
