My pc sometimes freezes for a few seconds then goes back to normal. They happen in game or while I am browsing the internet or using the computer in general such as using microsoft word. After using the computer about an hour or some it will randomly freeze for a few seconds howeber the next time it happens can be in another few hours or even after 10 minute. What is interesting is when the freezes occur it makes the sound as if the computer has gone to sleep and decided to wake up again. I'm lost I have reinstalled my operating system, removed and updated my GPU drivers, updated all drivers and windows updates. Any suggestions would be helpful.
Welp, since it's a case that can get lots of possibilities, try:
  • Test your RAM with Memtest86, run complete test on it (would be long 1-2 hours, but it's worth it). Could be possibility of defective RAM, and probably I thought this is the highest possibility.
  • Are you using SSD/HDD? Could be the drive's failing, at least check it's condition with CrystalDiskInfo/HWInfo.
Humor me, as you should do.
Daily drivers, below.
Diccbudd PC
AMD Ryzen 5 3600 || ASRock B450M Pro4 R2.0 Motherboard || MSI GeForce GTX 1650 Gaming X 4G || ADATA GAMIXX D35 2 x 8 GB DDR4 3200 MHz RAM || 480 GB Samsung PM981A NVME SSD // 480 GB Pioneer APS-SL3 SATA SSD // 1 TB Seagate 2.5" HDD || be quiet! System Power 9 500 W PSU || Deepcool AG300 CPU Cooler || Skyworth H27G30Q 2k 180 Hz Monitor || Logitech M650 Signature Mouse || Nuphy Air75 v2 Keyboard
Samsung Galaxy A34 5G
8GB RAM, 256GB Internal Storage, 128GB SanDisk Extreme, and you could find the rest of the specs on the interwebz lol
Lenovo ThinkPad L390 Yoga
Intel Core i5-8365U || 8 + 16 GB DDR4 (don't ask, gf bought me the 16 GB RAM as my birthday present lol) || Samsung 256GB SSD
Personal Server: HP Elitedesk 800 G3 SFF
Intel Core i3-7100 || Hynix 40GB DDR4 || 120GB random SSD || 1TB Toshiba 2.5" HDD
Audio
Redmi TV Soundbar || KZ EDX Ultra + KZ APTX Bluetooth Module || JCALLY JM6 CX31933 DAC
Add this aswell
Test large ffts (ram) and small(est) ffts (cpu) and see if any of em yeild errors or outright crash
Memtest is a good ram tester but i prefer prime95 cause it is usually alot more reliable than memtest, not to mention quicker at finding errors cause of how much it stresses your components
On 11/10/2021 at 5:44 PM, Somerandomtechyboi said:
Add this aswell
Thank youi for responding. I have checked the conditions of all my drives and they are in good health. I have used the free version of memtest86 and it found errors. It took 2 hours and 20 minutes to complete.
As for prime95 how long should the test last?
have you OC your system? changed some ram settings?
you could also try load default BIOS settings and redo the Ram test to be sure that the RAM is faulty.
I normally do round about 30 mins of prime95. But I do that for temperature checks.
Gigabyte X570 Aorus Elite,  Ryzen 9 3900x, Dark Rock Pro 4, 16 GB Crucial Ballistix  RGB 3600 MHz CL16 RAM, RTX 3080 TI FE Watercooled, 6 Case Fans,  Fractal Design Meshify S2
You are awesome, stay safe and healthy.
