Hi i have a Asus rog xg32vq monitor and its constantly scrolling down in the menu. if i hold the nipple up it stops scrolling as soon as i let it go it starts all over again and keeps turning on and off the keys lock. Iv got my partner to edit this as I'm dyslexic and was already told my grammar and the way i type is bad so I'm putting a link to a Youtube video of my problem. Any help or advice will be greatly appreciated.
Edited by billyp696969
https://linustechtips.com/topic/1386404-really-need-some-help/
39 minutes ago, billyp696969 said:
hi i have a asus rog xg32v and its constantly scrolling down in the menu if i hold the nipple up it stops scrolling as soon as i get it go it starts all over again and keeps turning on the keys lock it only happens after a hour or two of the monitor being turned on i do run dual screen and every now and then the rog screen looks like its turning on then off and my game switches to the second screen for about 5-10 seconds then switches back the rog monitor is a 2k 144 Hz screen and in only 2 years old is it dying as i only play games for about 3-4 hours a day
Could you edit your post, so that it is a bit more legible? Running sentences makes for poor reading (and grammar).
Thank you.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1386404-really-need-some-help/#findComment-15086660
